Would like to install Infinity driveshaft to differential bolts and nuts
2003 INFINITI G35
151,614,571 MILES • 3.5L • V6 • 2WD • AUTOMATIC
DUKE FLEED
Full set just as pictured driveshaft to differential bolts x4.
Will it give me limited slip differential effect? 1.5? 1.0? thanks so much.
Oct 2, 2019 at 7:09 AM
Good evening.
Are you changing your 2 wheel drive to all-wheel drive?
What have you done so far? That would be a huge project.
Oct 2, 2019 at 8:36 AM
DUKE FLEED
Thanks for reply. yes, i would like to change to 4 wheel drive if possible. Also interested limited slip differential will be 1.0 1.5 2.0 or 2.5? if 2.5 even exists. thanks
Oct 3, 2019 at 8:21 AM
Do you currently have a rear differential assembly for the all-wheel drive?
Oct 3, 2019 at 8:31 AM
DUKE FLEED
No, please tell me where to get the best one, and text some instructions. I will send you money for sure. thank you very much, bro ;)
Oct 4, 2019 at 1:04 AM
Okay, in order for this to happen, you will need a transfer case for the rear driveshaft, the driveshaft, and a different differential.
Once that is installed the car will have to be programmed to recognize the all-wheel system.
This will not be a cheap or easy job. It will require professional help.
Oct 4, 2019 at 5:20 AM
