Need to find the location of coolant temperaturesensor to replace it.
Jul 13, 2025 at 12:29 PM
MECHTRIX
✓Experienced Mechanic
Its usually on or near the thermostat housing on the cylinder head just follow the radiator hose to the engine it should be right around where the hose meets the engine it will have a 2-wire plug going to it . ..good luck
Jul 13, 2025 at 3:43 PM
Here is the location of the coolant sensor. Check out the images (below). Let us know how it goes.
