What size socket does it take to remove rear bearing hub nut? Need to know so I can purchase one.
May 18, 2017 at 12:52 AM
STEVE W.
✓Experienced Mechanic
Well the spec sheet says 30 mm, but I have seen those be wrong. Easy way to check, cut a 30 mm wide slot in a chunk of cardboard and see if it is a good fit........................................................................
