What size serpentine belt to bypass the AC
170,000 MILES • 4 CYL • 2WD • AUTOMATIC
ZABO FORSYTH
Serpentine belt broke due to A/C seize up. need to bypass the AC and need to know size of belt.
Jan 5, 2019 at 5:41 PM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
It is possible to bypass the A/C compressor but you need to understand that first the A/C compressor needs to be removed.After removal a idler/dummy pulley can be installed and a different size serpentine belt can be installed in its place.I can provide a diagram if needed.Hope this helps and thanks for using 2CarPros.
Danny-
Jan 5, 2019 at 6:01 PM
ZABO FORSYTH
Yes please send a diagram. Thank you
Jan 5, 2019 at 9:21 PM
ZABO FORSYTH
If at all possible. Can you please send a diagram of belt with AC and belt without AC? Thank you
Jan 5, 2019 at 9:24 PM
CJ MEDEVAC
  • 11,000 POSTS
I have a dumb question!
If you unplug the electrical connection from the A/C unit (actually the A/C clutch) will the pulley spin freely?
The Medic
Jan 6, 2019 at 11:27 AM
DANNY L
  • 5,648 POSTS
Hi CJ,
Yes, the pulley will always spin freely.That's the clutches job to engage the unit.Only time there's a problem is when clutch seizes and won't disengage, That's when belts get destroyed.
Danny-
Jan 7, 2019 at 2:44 AM
CJ MEDEVAC
  • 11,000 POSTS
But...
What if he's in A/C mode or heat with a defrost setting,
and Mr. Compressor locks down.
Belt cannot turn, belt gets destroyed.
Turn off A/C or heat with defrost settings or simply unplug the clutch so it cannot accidentally engage.
Clutch pulley now works fine as an idler only, the compressor is now a brick bolted to the motor.
It could be either a shot compressor or shot clutch pulley bearings (until it's confirmed).
I brought it up since it was not mentioned or tested to see which one went to pot. If it were the compressor shot, he could still get by without even taking it off.
The Medic
Jan 7, 2019 at 7:08 AM
POKER_DEALER
The answer is 61 1/8.
Sep 5, 2023 at 11:28 AM
