What seals/ bearings to replace with cv hal
185,000 MILES • 4.3L • 6 CYL • AUTOMATIC
WILLIEDYNAMITE11
  • 37 POSTS
I've recently or am in the process of replacing passenger side CV axle on an Drive Bravada was wanting to know if there are any seals or bearings I should replace in conjunction with replacing the CV axle and if so could you or do you know what they are part number by chance and what was the process be any light you can sit on the subject will be greatly appreciated
Mar 2, 2020 at 10:59 AM
The only major seal that you would want to replace is the axle seal that goes into the differential housing.
I don't have an OEM part number but here is a link to a major parts website. Just make sure you are selecting the front and not the rear.
https://www.rockauto.com/en/catalog/oldsmobile,2000,bravada,4.3l+v6,1364217,drivetrain,axle+shaft+seal,2336
Let me know if you have any other questions. Thanks
Mar 16, 2020 at 8:45 AM
