There is a part of the lower intake that I need to know where it goes?
1989 FORD BRONCO
200,000 MILES • V8 • 4WD • AUTOMATIC
KYLE351
I took apart the lower intake on my vehicle listed above and cleaned it up. I went to put it back together and cannot find this part and figure out what it is or what goes there?
May 12, 2023 at 10:48 AM
  • 110,244 POSTS
Is it possible for you to get a couple of pictures of the part and upload them for me to see? There really isn't a lot at the lower intake other than the manifold, so I'm not sure what you have.
May 12, 2023 at 3:33 PM
KYLE351
I figured it outm thank you. do you happen to know the torque specs for the upper half also what torque order?
May 13, 2023 at 3:37 AM
  • 110,244 POSTS
I'm glad you figured it out. As far as the torque specs are concerned, I attached a pic below that provided the torque and the sequence to tighten them.
The torque is listed in newton meters which is 33Nm. That is equal to approx 25 foot-pounds.
Let me know if that helps or if you have other questions.
See pic below.
May 13, 2023 at 3:39 PM
