Have to press accelerator in order to warm up the engine
2,245,006 MILES
If I start my car I has to press the accelerator down and up to make it warm the car
Dec 14, 2021 at 3:44 AM
Good afternoon,
It takes the engine run-up to 5 minutes before the heat develops in the car. The colder the weather, the longer it takes for the heat to work.
https://www.2carpros.com/articles/how-a-car-heater-works
Revving the engine does help some but it is not recommended. Check the coolant level to be sure it is correct.
https://www.2carpros.com/articles/car-heater-not-working
Does the engine temperature run normally? A stuck open thermostat would delay the engine in producing heat.
Dec 14, 2021 at 4:52 AM
