Engine losing power and misfiring?
121,000 MILES • 3.4L • V6 • 2WD • AUTOMATIC
WALKER TAYLOR
When the car gets up to about 30 35 MPH it's just like you push it into neutral and it's missing.
Aug 10, 2022 at 10:50 PM
  • 55,616 POSTS
Do you have a check engine light on? We should run the codes. You can get a code scanner from Amazon for about $20.00.
Here is a guide/video to show you how:
Here is a scanner link:
https://amzn.to/3Qi1SS6
Have you had an engine tune up recently? If not, I would start with that here is a guide to help you see how the job is done and instructions in the images below to show you how on your car.
https://www.2carpros.com/articles/how-to-tune-up-a-car-engine
Spark Plug Type .................... AC 41-940
1.52 mm (0.060 in)
15 Nm (11 lb-ft)
Also, do a throttle bore service.
Aug 11, 2022 at 4:45 AM
