When I press the brake it sound air and go down little
2007 LEXUS GX 470
55,265 MILES • 4.5L • V8 • 4WD • AUTOMATIC
MAFI DARE MICHAEL
When I start my car and press the brake it sound air and go down little bit, even on a motion when you press it down it sound air before catching.
Jul 17, 2019 at 11:16 PM
Hi Michael,
More than likely this is the brake booster. Do the brakes operate normally? If you have the engine off and you press the brakes, you will probably get 1-3 presses of the pedal before the vacuum is gone and the pedal gets hard. If this is the same noise you are hearing and the brakes are working then I suspect this is a normal condition.
Jul 19, 2019 at 6:05 AM
JIS001
  • 3,412 POSTS
Hello and welcome to 2carpros. Can you upload a video of the sound when you press on the brakes? I am asking because the GX does not have a brake booster? It has an acuator which is hydraulic and electric controlled? Attaching image.
Aug 3, 2019 at 3:47 PM
