Car went off while driving for two seconds?
137,795 MILES • AUTOMATIC
BRITTANY_
Car went off while driving for two seconds and then came back on with my ABS and check engine light at first but then the ABS left once car kicked back on. Went to have the code read and got these -
P0882, U3003-16, U3003-17, U0131-00,
U0001-88, C0051-67, U0401-00.
Not sure exactly what kind of issue this means for repairs, the battery is a couple months old as I thought this was the original issues a few months back.
Aug 19, 2026 at 6:51 AM
  • 55,688 POSTS
Hello, The big clue is P0882, TCM power supply voltage low which a loose battery terminal can causes. I would check out this guide first to see if that is the problem. If you find the terminal loose or corroded try cleaning it and then clear the codes and drive it. Then run the codes again.
https://2carpros.com/articles/everything-goes-dead-when-engine-is-cranked/
I would not replace the ABS module, transmission control module, or other modules based on these codes yet. A momentary loss of voltage can cause several modules to shut down and generate communication codes at the same time. Let me know
Aug 20, 2026 at 4:59 PM
