What are the torque specs for the cylinder heads?
200,000 MILES • 5.3L • V8 • 4WD • AUTOMATIC
MARIOBUCIO
What are the torque specs for aluminum cylinder heads?
Nov 8, 2022 at 11:55 PM
  • 55,628 POSTS
So, these have torque-to-yield head bolts and cannot be reused so make sure you get a new set of bolts. I have found the instructions on how to install the cylinder head with torque specs and a video that shows the job being done. Be sure to check out the images below for the information.
https://youtu.be/JDN8MaekT2Y
Check out the images (below). Please let us know if you need anything else to get the problem fixed. These instructions work for both sides.
Nov 9, 2022 at 3:51 AM
MARIOBUCIO
Thank you, so much very helpful information.
Nov 9, 2022 at 3:56 AM
  • 55,628 POSTS
Use 2CarPros anytime, we are here to help. Please tell a friend.
Nov 10, 2022 at 1:28 AM
