What is this sound? Van won't start?
What to check next
Diagnostic guidance. Suggested checks and possible repairs are separate from the owner's reported results.
First identify the humming component and the actual cooling-fan arrangement. A stiff blade alone does not establish an electric fan-motor failure; a mechanically driven fan or clutch needs different evaluation. Keep hands away from fans and belts, and do not leave a suspected stalled electrical component energized unattended. Have a technician isolate the key-off electrical load using the vehicle's wiring information, then determine whether the no-start means no cranking or cranking without firing. Battery condition and the starting circuit need checking after the discharge. Separately inspect the cooling system before running or driving an engine that overheated. Replace a fan, relay or other component only after identifying the fault, then verify both cooling and normal key-off current draw. Separating these checks can show whether there is one shared problem or more than one.
Guidance references and applicability
Fluke: Automotive multimeter tests https://www.fluke.com/en-us/learn/blog/digital-multimeters/common-automotive-testing-with-a-multimeter General background for battery, starting-circuit and parasitic-drain diagnosis. HELLA: Cooling-system check https://www.hella.com/techworld/ae/technical/car-cooling-system/cooling-system-check/ General cooling checks. Neither reference identifies this van's fan arrangement or the humming component.
Discussion summary
The owner described overheating followed by a persistent key-off humming noise, overnight battery discharge and a no-start despite charging and trying another battery. They later identified the vehicle as a 2001 Dodge Ram Van 2500 and said a fan blade felt stiff. A contributor recommended a fan motor, but the referenced video was unavailable and the component was not verified.
Reported outcome: No fan replacement, electrical-load diagnosis or restored starting was reported.
The engine, fan arrangement and no-start type were not established. The mentioned video was not available for review. A locked electric fan motor is not a confirmed diagnosis.
