What is this piece on top of manifold called?
119,000 MILES • 6 CYL • TURBO • 2WD • AUTOMATIC
BHAMDOC1973
  • 2,007 POSTS
About to reinstall the intake manifold. There is a sensor on the top right of the intake that pops into a grommet which i have lost and i want to try to buy the grommet. Do you know what this sensor is? Temperature sensor maybe? This is a 335d diesel,
Jun 18, 2022 at 7:31 AM
SQM
  • 6,383 POSTS
This is the Manifold Absolute Pressure Sensor (MAP).
The MAP sensor sends data to the ECM for it to control air fuel mixture.
You might have to purchase a new sensor as most of the time the grommet is not available by itself.
Let me know of any questions.
Jun 18, 2022 at 9:38 AM
BHAMDOC1973
  • 2,007 POSTS
Got it, thanks.
Jun 18, 2022 at 10:01 AM
BHAMDOC1973
  • 2,007 POSTS
What does it do? If i just leave it hanging and start the car for now would i get a rough idle? I found the rubber piece online.
Jun 18, 2022 at 10:04 AM
SQM
  • 6,383 POSTS
The MAP signals the ECM to help determine how much fuel to provide. So, it will likely run rough and trigger the check engine light.
Jun 18, 2022 at 12:12 PM
