The MAF will cause drivability issues such as hesitations. That could result in other issues. The sensor is used by the powertrain control module (PCM) to determine the amount of air entering the intake. With that information, the PCM knows how much fuel to add to make the vehicle run as efficiently as possible.
If the fuel mixture is off (very rich) it could cause damage to other components. For example, the catalytic converter could be damaged. If it plugs, it could cause overheating.
The transmission is the one that is most questionable. If the engine isn't running properly, the transmission may experience changes in shifting patterns.
What is happening with the vehicle? Have you scanned the computer for diagnostic codes? If so, what codes have been retrieved?
joe
Oct 31, 2023 at 11:00 AM
