What is this disconnected harness on my undercarriage
50,000 MILES • 4 CYL • 2WD • MANUAL
ALEXIS NOEL EVANS
Just needing to know what harness it is and what it controls. Appears to have been disconnected for a while.
Apr 12, 2019 at 2:01 PM
  • 110,248 POSTS
Welcome to 2CarPpros.
There are many different wiring harnesses under the vehicle. Can you upload a picture of it, tell me the colors of the wires going to it, and approximately where it is located?
Thanks.
Apr 12, 2019 at 2:30 PM
ALEXIS NOEL EVANS
Sorry I did post photos when I asked but they must not have uploaded. Trying again. this would be about under the passenger floor board.
Apr 14, 2019 at 9:47 AM
ALEXIS NOEL EVANS
The only issues I know of is a check engine light that never turns off and my A/C has never worked. Mechanic thought it’s the compressor but I’m hoping it’s this stupid plug, lol. if I could be so lucky.
Apr 14, 2019 at 9:48 AM
  • 110,248 POSTS
Welcome back:
Looking at the plug, it appears to either be a connector for a wheel speed sensor or even a fog light. What color are the wires under the black tape? Does your vehicle have fog lights that work or none at all?
As far as the check engine light, you need to scan the computer to retrieve diagnostic trouble codes. They will indicate what is causing the light to be on. If the car runs fine, chances are you will find it is an evaporative emissions code (EVAP).
Here is a quick video showing how to scan a computer:
https://youtu.be/YV3TRZwer8k
I realize most people don't own a scanner, but often times parts stores will scan it for free and tell you the codes. If you can do that, let me know what codes are found and I can help you get that taken care of too. As far as the AC, when you turn it on, do you hear a click from under the hood indicating the compressor has engaged? Take a look through these links and see if there is something that can help you. If you have questions, let me know and we'll try to get that taken care off too.
If you can tell me the color of the wires, I can look through schematics to try and find exactly what they are for. Maybe with a little luck, it will be something with the AC.
I will watch for your reply.
Apr 14, 2019 at 10:28 AM
