repair a strap mount that stripped and change the fuel pump?
361,000 MILES • 3.3L • V6 • 2WD • AUTOMATIC
SANDSTORM58
  • 16 POSTS
dropped the empty fuel tank to get it away from the vehicle to repair a strap mount that stripped and change the fuel pump. tilted the tank to check if all the fuel was out and heard something banging around inside. if I'm correct it's the fuel vent valve that connects to the 1/2-inch flex tubing from the filler tube. what you see is what i found plus a lightweight spring. Someone please tell me how it goes back together then i'll take care of it before installing the new fuel pump. i know it snaps into place but not how the three pieces fit together. i think it may have dislodged when moving the pump around and disconnecting the 1/2-inch flex vent tubing. see photos. what is this and where does it go?
Sep 8, 2022 at 2:26 AM
  • 55,746 POSTS
I have never seen this part before; I think it might be part of the manufacturing process that was accidentally left inside the tank. Here are the instructions to help you change the pump out. Check out the images (below). Please let us know if you need anything else to get the problem fixed.
Sep 9, 2022 at 4:42 AM
SANDSTORM58
  • 16 POSTS
I already know how to change pumps. The questionable piece I found out from Chrysler is the Fuel Vent Valve for the 1/2" vent from filler tube.
Sep 16, 2022 at 9:31 AM
  • 55,746 POSTS
Good to know I have never seen one before. Thanks for getting back to us.
Sep 16, 2022 at 9:33 AM
