A/C passenger side blowing hot air
200,000 MILES • 3.0L • V6 • 2WD • AUTOMATIC
5STAR
Air conditioner line in engine compartment very cold, but inside passengers area it blows all hot air.
Aug 15, 2018 at 4:04 AM
Good afternoon.
I will need gauge readings of the AC system on the high and low side to see if the system is working correctly.
Do you have a set of gauges? If you do not then you can rent a set at a parts store.
Once I get those readings, I can further help you.
Aug 15, 2018 at 6:01 AM
