Shut off while driving
1,700,000 MILES • 2WD • AUTOMATIC
MISSBARNES
I forgot when driving it would act like it wasn't getting enough gas so I would push to give gas. at that time had half a tank but at times going up hill it did this too. However, this last time I was driving up a little hill and did a u turn and it shut off but started back up. last time I started it it acted like it wasn't getting gas. i haven't driven it since because I'm scared that I'll be driving and it will do it again.
Feb 2, 2021 at 7:27 AM
  • 110,248 POSTS
Based on your description, it sounds like you are on the right track. It sounds like you have a weak fuel pump. What needs to be done is to check fuel pressure. Here is a link that explains how in general pressure is tested. You will need a fuel pressure gauge. I realize that isn't something most people have, but oftentimes, a parts store will lend one to you.
Here is the link:
Here are the manufacturer's specs as far as fuel pressure.
2006 Chrysler Pacifica V6-3.5L VIN 4
Pressure, Vacuum and Temperature
Vehicle Powertrain Management Fuel Delivery and Air Induction Fuel Pump Fuel Pressure Specifications Pressure, Vacuum and Temperature
PRESSURE, VACUUM AND TEMPERATURE
FUEL SYSTEM PRESSURE
400 kpa ±34 kpa (58 psi ± 5 psi)
Take care and God bless,
Feb 2, 2021 at 10:13 AM
