Codes P0137 and P0332
95,000 MILES • 3.5L • 6 CYL • 4WD • AUTOMATIC
LARRY BIRT
Codes P0137 and P0332 both indicate low voltage. What is common to Knock and B1 O2 Sensor 2?
Apr 25, 2019 at 6:49 AM
LARRY BIRT
That was supposed to be P0327: Bank 1 knock sensor low And P0137: O2 Sensor Circuit Low Voltage (Bank 1, Sensor 2)
Apr 25, 2019 at 11:57 AM
Good afternoon,
The 327 is a knock sensor. The possibilities are below:
P0327
Descriptor
Probable Causes
Engine Control Module (ECM)
Knock Sensor
137
P0137
Descriptor
Probable Causes
Diagnose Other DTCs First
Engine Coolant Consumption
Engine Oil Consumption
Fuel Quality
Heated Oxygen Sensor (HO2S)
Heated Oxygen Sensor (HO2S) Bank 1 Sensor 2
Legend
Collision Roy 3
Change Vehicle Bookmarks Library Request Conversion Calculator Technician's Reference - Collision
Oxygen
63
Community 7 Create Quote
2008 Saturn Truck VUE AWD V6-3.5L
Components
Vehicle Powertrain Management Sensors and Switches - Powertrain Management Sensors and Switches - Computers and Control Systems Oxygen Sensor Locations Components
COMPONENTS
Powertrain Component Views
Top View of the Engine
1 - Fuel Injector 6
2 - Fuel Injector 5
3 - Fuel Injector 4
4 - Camshaft Position (CMP) Sensor
5 - Fuel Injector 1
6 - Fuel Injector 2
7 - Fuel Injector 3
Top of the Engine
1 - Generator
2 - Ignition Control Module (ICM)
3 - Manifold Absolute Pressure (MAP) Sensor
4 - Throttle Actuator Control (TAC) Module
5 - Evaporative Emissions (EVAP) Canister Purge Solenoid
Front of the Engine
1 - Heated Oxygen Sensor (HO2S) Bank 2 Sensor 1
2 - Engine Coolant Temperature Sensor
3 - Transmission Control Module (TCM)
4 - Fusible Link
5 - Starter
6 - Knock Sensor (KS) Bank 2
7 - Engine Oil Pressure (EOP) Switch
8 - Heated Oxygen Sensor (HO2S) Bank 2 Sensor 2
9 - A/C Compressor Clutch
10 - A/C Refrigerant Pressure Sensor
Rear of the Engine
1 - Knock Sensor (KS) Bank 1
2 - Heated Oxygen Sensor (HO2S) Bank 1 Sensor 1
3 - Camshaft Position (CMP) Actuator Solenoid
4 - Engine Block Heater Connector (K05)
5 - Crankshaft Position (CKP) Sensor
6 - Heated Oxygen Sensor (HO2S) Bank 1 Sensor 2
Apr 25, 2019 at 12:17 PM
