what is code p0016
95,643 MILES • 2.0L • 4 CYL • 4WD • AUTOMATIC
MAUVELINE PRESTON
It will crank and start sometimes then sometimes it cranks and will not start. I have to wait a minute or two.
May 5, 2016 at 11:49 AM
HMAC300
  • 48,601 POSTS
This code can mean the timing chain system is worn and needs to be replaced. I would try making sure the engine oil is full as well.
May 6, 2016 at 12:19 AM
RENEE L
  • 1,260 POSTS
The code P0016 leads to the crankshaft and camshaft position sensors. Here are some possible causes for this code: Timing chain stretched, or timing belt skipped a tooth due to wear, misalignment of timing belt/chain, tone ring on crankshaft slipped/broken, tone ring on camshaft slipped/broken, bad crank sensor, bad cam sensor, damaged wiring to crank/cam sensor, or timing belt/chain tensioner damaged.
May 6, 2016 at 6:43 AM
