What is a splice
2008 CHRYSLER PACIFICA
115,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
JR9261018
  • 49 POSTS
I looked on Alldata for location and I saw splice location. My question is, what is a splice? Is it two wires soldered together a connector or what?
Oct 23, 2018 at 5:38 PM
  • 110,194 POSTS
Yes, it is where wires are joined together. Often times, they are crimped together and not soldered.
If you have other questions, let me know.
Oct 23, 2018 at 6:15 PM
JR9261018
  • 49 POSTS
this video is recorded when key on engine off.when i depin two B+ wires from the pcm C! connector it does same thing you see in the video so i suspecting the splice between ignition switch and the B+ wire going to the pcm . the splice is s118 how to locate it?
Oct 24, 2018 at 8:57 PM
  • 110,194 POSTS
Hi again. I'm not sure what problem you are dealing with. However, based on what you have said, it sounds like a start issue. Is that correct? As far as the s118, please reconfirm that number. I just looked through every schematic and can't locate it. I found s117 and s119. My next question is this. Power to the PCM is supplied through the TIPM (total integrated power module). These are very common to have issues because of the small pin size and corrosion. Looking at schematics, I'm seeing pins 4 and 5 providing power to the system via the ignition. Have you checked them?
Let me know exactly what is going on. Also, what engine is in the vehicle. The 2.4L wasn't offered in this vehicle.
Joe.
Oct 25, 2018 at 5:55 PM
JR9261018
  • 49 POSTS
The problem is sometimes not always when I turn the key to run position engine off I see what's in the video after I crank it and the car start normally however the car goes in limp mode with p0882 code.so what I did I disconnected the c1 connector , turned the key on run position engine off and I saw what's in the video so I said the problem is tin that connector.to pinpoint where exactly I Depin two power wires from c1 connectors one comes from ignition switch the other from tipm and connect back the c1 connector turn key on engine off and I saw what's in the video so my conclusion is the problem is in those two powers one of them has a splice the other not. So I want to check the s118 splice for problems
Oct 25, 2018 at 7:41 PM
JR9261018
  • 49 POSTS
Sorry c1 connector is the pcm one
Oct 25, 2018 at 7:43 PM
  • 110,194 POSTS
Take a look at this schematic and tell me if you are referring to pins 10 and 29. If you are, the only splice I can find is s151.
Oct 26, 2018 at 5:48 PM
JR9261018
  • 49 POSTS
I will post an image of the splice if i can
my question is . is the problem in those two B+ wires which make the car goes to limp in mode.if yes what could be the problem is it the female pins the wire itself or the splice. if yes how to pinpoint
Oct 27, 2018 at 5:37 AM
JR9261018
  • 49 POSTS
its #11 its ignition switched and 29 came from tipm.when i disconnect those two pins from the pcm connector, connect back the connector to the pcm and turn the key to run position engine off the recreate the problem that i have shown on the video
Oct 27, 2018 at 5:57 AM
  • 110,194 POSTS
This is really interesting. Your wiring schematic looks different than mine. What size engine does it have? To answer your question, 99% of the time it is the actual pins on the tipm. They bend or corrode and break.
I looked on my schematic. Both B+ terminals are to power the fuel pump (at least that is what my schematic is showing me). I don't see how that would put it into limp mode.
Oct 27, 2018 at 9:14 PM
JR9261018
  • 49 POSTS
sorry I think I selected the wrong car its 2006 pt cruiser 2.4 auto non turbo
there is one coming from ignition switch and the other from Tipm
when the key is on engine off and the car acting up I back probed those two B+ and i see 12v
Oct 28, 2018 at 11:25 AM
  • 110,194 POSTS
That makes a difference. The splice is located on the left front side of the engine compartment. See attached picture.
Let me know if this helps.
Oct 28, 2018 at 9:18 PM
JR9261018
  • 49 POSTS
So what I need to look for? And on the image what those doted line coming from the ignition switch to pin 11 of the PCM means?
Oct 29, 2018 at 10:07 PM
  • 110,194 POSTS
The dashed line indicates it is a switched power. Have you checked the splice?
Oct 30, 2018 at 5:37 PM
JR9261018
  • 49 POSTS
Not yet also the car is not acting up because the outside temperature is cold. It is something related to heat.
Oct 31, 2018 at 4:19 AM
  • 110,194 POSTS
Okay... Let me know what you find with the splice. Hopefully, it won't give you any trouble regardless of temp.
Oct 31, 2018 at 7:03 PM
JR9261018
  • 49 POSTS
I did not find the splice?
When I depin pin#11 from connector C1 of the PCM and connect all PCM connectors back the car does exactly the same as shown on the video. Also 5 volts reference is present, when I depin pin#12 the car does not act up. When I depin pin# 29 aka remove the fuse the car acts up the difference is there is no 5 volts reference. FYI when the car acting up as in the video there is 5 volts reference so I am sure the problem is in pin#11. The other thing is when the car acts up and back probe pin#11 there is battery voltage
Pin #11, 12, 29 are all in C1 connector of PCM.
Nov 6, 2018 at 1:06 PM
  • 110,194 POSTS
Welcome back.
Are you referring to the TIPM C1 connector or the PCM? The C1 connector on the TIPM pin 11 is not used. Pin 11 on the PCM is for injector 4. See the attached pictures.
Nov 6, 2018 at 6:03 PM
JR9261018
  • 49 POSTS
I corrected the car on one of my answer it is 2006 PT Cruiser 2.4 L non turbo automatic. Sorry. I am talking about C1 of PCM this is the diagram.
Nov 7, 2018 at 11:23 AM
