What engine do I have? ls1 2 gen 2 design lm7?
200,000 MILES • 5.3L • V6 • 2WD • AUTOMATIC
DOUG HOOK
i don't seem to have any steam ports.I thought i had a ls1 2 gen 2 design lm7.
After watching all your YouTube videos I am not sure what I have. if. It helps The head bolts were all medium length. A second question, can I eliminate the knock sensors? What do i need to do to eliminate them?
Oct 6, 2022 at 9:29 AM
RYAN L
  • 273 POSTS
All LS based engines have steam lines as far as I'm aware. If all the head bolt lengths are the same, then it is a gen 2 LM7. Yes, you can if the engine is not going into an emissions-controlled vehicle like an old hot rod. Just get a valley cover without them and then program your ECU to ignore them. Thanks for watching!
Oct 7, 2022 at 8:01 AM
