I've bought some OEM CV axles for my vehicle car listed above and I am wondering, what else should be done along with replacing my leaky CV axles? Power steering fluid flush? Is it like transmission fluid where I shouldn't flush it but only drain/fill? Any other parts I should change out while already replacing both CV axles? I've already done struts, inner and outer tie rods, both lower control arms, front sway bar links (still need to do rear, so I suppose I'll get those). I know I do need an alignment as my car is pulling to the right pretty bad.
Jun 5, 2020 at 6:25 PM
