Code P0015, and Tra mode and limp mode keep displaying?
143,700 MILES • AUTOMATIC
SELBEY
Recently I got my car back. Repaired cracked radiator, gas tank leak, valve cover gasket. My battery was dead, so they gave me a used one. They told me there is still a leak they can't find. The car is now displaying coolant warning. I put fluid in daily and by the time I get to my destination, the coolant display is back! I got the OBD code P0015, and Tra mode and limp mode keep displaying as well! The mechanic advised me to first replace my battery; and that may solve some of my problems. But I need to fix the leak problem. They said it may be the water pump. Help!
Apr 20, 2024 at 2:59 AM
STEVE W.
  • 15,414 POSTS
There are only a couple places the coolant can be going, either an external leak or there is a bad gasket, and the engine is sending it out as steam. An external leak shouldn't be hard to find if it's losing that much as it will leave deposits and staining. What I suggest is to go to a parts store and get a radiator pressure test kit and some leak detection dye. Then top up the coolant and add some dye with the engine cold and set up the tools.
https://www.2carpros.com/articles/radiator-pressure-test
Remove any shields and such that block your view. Now for the initial test with a cold car, get the gauge in place and start the engine and watch the pressure gauge. When you first start it, you shouldn't see any pressure reading, then after the engine starts to warm up the pressure should start to rise. If on the other hand you start the engine, and the gauge goes up very fast in a short time (usually this would be less than a minute) you can shut it off and know that you have a blown head gasket. If there is no change, shut the engine off. Now use the manual pump to raise the pressure up to about 15 PSI. Let it set. If there is no leak the pressure will stay the same. Ig you have a leak then it's time to go hunting. Take a UV light and start looking for the glow of the dye. Check all around the engine, radiator and check the heater core as well. The leak should show up rather easily. As the shop you are using cannot find a leak, find a better shop. I suspect, based on the items you had replaced and the coolant loss, that it's a bad head gasket. Testing should show either a leak or a bad gasket.
Apr 20, 2024 at 3:20 AM
SELBEY
Thank you so much for your answer. I appreciate it!
Apr 20, 2024 at 3:56 AM
STEVE W.
  • 15,414 POSTS
You are welcome. Please return and let us know what you find.
Apr 20, 2024 at 6:33 AM
