what do radiator hoses hook to?
140,000 MILES • 3.6L • V6 • 2WD • AUTOMATIC
GEODIN_2021
  • 5 POSTS
Trying to figure out what the part is called that the upper and lower radiator hoses hook to?
Jul 9, 2021 at 12:22 PM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
Here is the information you requested. Here is a tutorial showing how to replace radiator hoses:
https://www.2carpros.com/articles/replace-radiator-hoses
I've attached a diagram below showing the radiator hose locations and replacement steps for your Kia. Hope this helps and thanks for using 2CarPros.
Jul 9, 2021 at 3:49 PM
GEODIN_2021
  • 5 POSTS
That is good, however I'm looking for name of part that the housings hook to.
Jul 10, 2021 at 4:38 AM
  • 110,248 POSTS
I'm not sure if you made progress on this. it has been a couple of days since we heard from you. Regardless, the housings you referred to are the thermostat housing and the water outlet housing.
I attached two pics below to help you identify them.
I hope this helps. Let me know if you have other questions or if there is something I can do to help.
Jul 12, 2021 at 2:08 PM
GEODIN_2021
  • 5 POSTS
Maybe I am not being clear, I am looking to find out the name of this part.
Jul 13, 2021 at 1:24 AM
  • 110,248 POSTS
That entire assembly is called the thermostat housing. I call it a crossover pipe, but Kia calls it a thermostat housing. The OEM part number is 25620-39521.
Look up "Kia part number 25620-39521" and you'll find it. That is the exact part number for the vehicle listed above.
Let me know if that helps.
Jul 13, 2021 at 2:26 PM
DANNY L
  • 5,648 POSTS
Hello again.
That is called the thermostat housing. The thermostat and water outlet attach to the assembly. I've attached the factory Kia part number and price below. Hope this helps and let us know if you have any further questions about this. Thanks again for using 2CarPros.
Danny-
Jul 13, 2021 at 2:32 PM
GEODIN_2021
  • 5 POSTS
Thank you for all for your assistance.
Jul 14, 2021 at 2:12 AM
DANNY L
  • 5,648 POSTS
You're welcome!
Thanks again for using 2CarPros and we hope you will use our site again in the future when needed.
Danny-
Jul 14, 2021 at 10:56 AM
