what do i need to replace , i believe its a sensor
V6 • 2WD • AUTOMATIC
RUSSELL W MOORMAN
Car has massive loss of power, seems as if the motor is not firing on all pistons. If it is, their not in order, running very rich(gas smell). When it originally started I preformed a tune - up on car . It then ran normal for 1-2 days and then everything I put above. Also if I get the car to high speeds, it does not seem as anything is wrong.
Jun 29, 2014 at 7:58 AM
WRENCHTECH
  • 20,758 POSTS
Your diagnosis should start with scanning for stored trouble codes. That should at least tell you which cylinders have the problem.
Jun 29, 2014 at 8:22 AM
