What do i do for a code p1633?
191,700 MILES • 4.6L • V8 • 2WD • AUTOMATIC
NIGHTBLADE53142
Engine light came on one day so i checked the code but i am unsure what i need to do about it. Any advice or help would be appreciated.
Jun 24, 2025 at 11:49 PM
  • 55,770 POSTS
Yep, this means the voltage in the system is too low, when the engine is running do you have a battery warning light on? If so the alternator might be to blame as it is not charging.
P1633 - Keep Alive Power (KAP) Voltage Too Low
You can use this guide to confirm the alternator is working okay and if so, I would replace the battery.
Please go over this guide and get back to us.
Jun 25, 2025 at 5:18 AM
NIGHTBLADE53142
Battery light would come on once in a blue moon but when i tested my battery and alternator the tester said they were good, but the battery is starting to get old so i could try replacing that.
Jun 25, 2025 at 9:50 AM
  • 55,770 POSTS
Okay, also, check all fuses int he under hood fuse panel, you might have one that is out.
This guide can help:
Please go over this guide and get back to us. Check out the images (below).
Jun 25, 2025 at 11:47 AM
