Car sways after new tires, wheel bear, control arm replaced
500,000 MILES
TINA KAPLAN
  • 6 POSTS
I recently had new tires put on my car, wheel bearing, and a control arm rear lower rearward control arm. After getting everything balanced put on the car now sways dog tracks whatever , but it also makes a grinding noise. what could it be?
Mar 27, 2018 at 1:23 AM
Good afternoon.
If it dog tracks, something is bent and out of line.
Did the shop perform an alignment? if they did, do you have a copy of the print out with the results? it would be great if you could post it here.
Mar 27, 2018 at 6:33 AM
TINA KAPLAN
  • 6 POSTS
No alignment was done. When I go forty five mph or more you cannot hear the noise much, but when I hit a bump it makes the rear fish tail, very concerned. I can hear the grinding more so when backing up it is like a deep grinds with deep creaking.
Mar 27, 2018 at 4:55 PM
TINA KAPLAN
  • 6 POSTS
Hope that makes sense.
That makes sense, but the next step is to have a alignment performed. this will tell if the car is not within specs.
Once you have it done, get a copy of the print out and post it here for us to view.
Mar 27, 2018 at 8:30 PM
TINA KAPLAN
  • 6 POSTS
Okay, money is tight I am trying to figure out cheapest route at this moment. The car drives fine tested the alignment on my way to work car drove perfectly straight until I hit a bump that sent the rear Into a frenzy.
Mar 27, 2018 at 10:16 PM
that indicates either loose or worn parts in the suspension. you can get a shop to do a suspension check free for you to find the failures.
Mar 27, 2018 at 10:20 PM
TINA KAPLAN
  • 6 POSTS
I figured since he did the lower control arm maybe he did not tighten some bushings very well that I would start by getting new bushings. Thank you I just did not know whether it was the suspension or the sway bar.
Mar 28, 2018 at 12:13 AM
You are welcome.
Get the entire suspension checked.
Mar 28, 2018 at 12:15 AM
TINA KAPLAN
  • 6 POSTS
Will do on my next day off. thank you again.
Mar 28, 2018 at 12:40 AM
You are welcome.
Mar 28, 2018 at 1:07 AM
