What could cause the left drive shaft to vibrate when accelerating?
241,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
KAOMA
  • 24 POSTS
My car has a vibration on the left drive shaft. This vibration happens when accelerating either at low or high speeds. The vibration is always there, the moment i stop accelerating, the vibration stops and runs smoothly, when i start accelerating i can i feel the vibration. i have tried to change the inner CV joint, outer CV joint, the drive shaft and today i went as far has change the differ in the gearbox, despite doing all this i still have the vibration. Please note that this problem started last year after i replaced the gearbox. Please help, how can i fix this problem?
Jul 22, 2023 at 4:32 AM
  • 55,612 POSTS
If you have already replaced the inner and outer CV joints, the drive shaft, and the differential in the gearbox
Jul 22, 2023 at 9:44 AM
KAOMA
  • 24 POSTS
Hi Ken, thanks for your response. sorry i did not mention this in my first post. The wheel bearing was replaced, the suspension was replaced and axle was replaced, despite this, the problem did not go away.
Jul 23, 2023 at 1:24 AM
  • 55,612 POSTS
I would rotate the tires front to back, I have seen a tire come apart internally and it will cause this kind of problem.
Jul 24, 2023 at 3:55 AM
KAOMA
  • 24 POSTS
Alright i will try that, though i just replaced the tires like 2 months ago. thank you
Jul 24, 2023 at 4:26 AM
  • 55,612 POSTS
Please let us know how it goes.
Jul 25, 2023 at 11:35 AM
