What could cause my idling to go up to 3000-4000 rpm's in neutral?
Aug 25, 2017 at 9:27 AM
HARRY P
✓Experienced Mechanic
I would suspect either a bad idle air control valve or a vacuum leak (specifically the intake manifold gasket) if there is no service engine light. If there is a light, get it scanned and let us know what the code(s) it has. You can get that done at the local auto parts shop.
