Electrical issues
103,000 MILES
NICOLEHAM85
Needing help with my car listed above LX model. While driving in my music stops when using auxiliary port and when the AC is on it causes all my warning lights to come on.
Jun 8, 2019 at 10:54 AM
JIS001
  • 3,412 POSTS
If all lights come on when using the A/C then check your alternator for low charge. Here is a link to checking the alternator:
Let us know what the test results are please to better guide you.
Jun 8, 2019 at 3:37 PM
NICOLEHAM85
Had the battery and alternator checked there was no issues with either.
Jun 8, 2019 at 3:41 PM
JIS001
  • 3,412 POSTS
How did they check? Was the charging test done in the car and what was the numbers? Is the fault all the time or after your vehicle runs for a while?
Jun 8, 2019 at 4:41 PM
NICOLEHAM85
They did a charging test. 12.66 for the battery and 13 for the alternator. Only when I use the AC and when i use the audio auxiliary port to play my music through my phone. As long as I don't use the AC and audio auxiliary port for music no warning lights don't show.
Jun 8, 2019 at 10:55 PM
JIS001
  • 3,412 POSTS
13 volts is low and it probably goes lower when using the A/C for a while. You should check the charging system when all the warning lights start lighting up and the music stops playing.
Jun 9, 2019 at 2:45 PM
