40 amp ignition fuse keeps blowing
150 MILES
MYSTICWOLF2219
I keep replacing a 40 amp fuse that is for my ignition. I have looked at all wires to the engine and to the battery no problems there. I am having trouble takeing the steering column apart but so far no wires that look to be problematic. What is going on?? How to fix and find the problem.
Nov 17, 2013 at 7:01 PM
HMAC300
  • 48,601 POSTS
that goes to the ignition switch and starter relay so try switching the starter relay with a like relay and see if that cures it if not it may be a bad ignition switch. This guide can help
Nov 17, 2013 at 10:34 PM
