A fuse blows because of a short to ground, before the load, in the circuit[s] that it is protecting. This happens because of Ohm's law, which are the laws that govern electricity. One of Ohm's laws states that if one of the three properties of electricity is constant[Voltage-Battery Voltage is always constant in an automotive electrical circuit] and one of the remaining two properties go down [Resistance=Resistance goes to zero when the electrical path takes a short circuit back to the negative battery terminal before the load] then the last property [Amperage/Current-Amps go to battery amperage] must go up proportionally. The amperage becomes more than the amperage rating of the fuse and "pop" the fuse blows, creating an open in the circuit, protecting it, just like it was designed to do.What was the exact fuse in your vehicle that blew? We can send you wiring diagrams and a guide on how to find the short the ground when we get the exact fuse that blew.
Thanks,
Alex
2CarPros
Dec 4, 2019 at 4:54 PM
