1998 Nissan Altima 100 amp fuse
JENNYBARNETT56548
  • 1998 NISSAN ALTIMA
  • 4 CYL
  • FWD
  • 100,000 MILES
How do you remove 100 amp fuse. It will not pull out. Is there a bolt or screws holding it in, if so how do you get to the bolt or screw
Friday, January 25th, 2008 AT 6:39 PM
2CARPRO JACK
  • 11,533 POSTS
If not visible from the top, may have top remove the power block and take the bottom off it to access the screws
Saturday, January 26th, 2008 AT 8:08 AM
JACK JENNINGS
Gee, when you want help, you only get the run around. To remove this fuse, you have 2 clips below both side on the side that have a screw that will have to be removed before you can pull the fuse.
Saturday, October 6th, 2012 AT 9:18 PM
