My car is making a rattling noise. could it be the faulty steering rack or the brake calipers?
Nov 28, 2016 at 9:43 PM
HMAC300
✓Experienced Mechanic
this is kind of a loose description. does it do it just parked/driving etc. check for loose or broken shields under car like maybe pins missing or the converter shield rattling against the converter because rivets broke.
Nov 28, 2016 at 9:53 PM
KEENAN112
MEMBER
Thank You.
Nov 28, 2016 at 10:20 PM
KEENAN112
MEMBER
Whenever the car is on a bad patch of road it makes a lot of rattling noises inside the car. what could be the possible reason??
Nov 28, 2016 at 10:38 PM
KEENAN112
MEMBER
i20 automatic. When ever the car is on a bad patch of road it makes a lot of rattling noise inside the car.what could be the possible reason??
Nov 28, 2016 at 10:39 PM
KEENAN112
MEMBER
Please tell me what can be done to fix it.
Nov 28, 2016 at 11:29 PM
HMAC300
if it is a bumpy road or bad patch like you say it can still be what I said or a front end problem so have that checked.
