What are the torque specs for front end wheel bearing bolts?
59,000 MILES • 2.8L • V6 • 2WD • AUTOMATIC
OLDGMLOVER
  • 20 POSTS
I need torquing specs for the front wheel bearing bolts.
Aug 11, 2022 at 2:21 PM
  • 110,248 POSTS
Are you referring to the axle nut?
I attached directions for the replacement of a drive axle. I don't know if that was done or if the hub itself was replaced. However, the directions provide the needed torque specs.
Take a look through the attachments and let me know if you have other questions.
Aug 11, 2022 at 3:10 PM
OLDGMLOVER
  • 20 POSTS
Thanks, I got the info. The info sent will work. Thanks again.
Aug 12, 2022 at 12:49 AM
  • 55,627 POSTS
JACOBANDNICKOLAS is one of our best! Use 2CarPros anytime, we are here to help. Please tell a friend.
Aug 12, 2022 at 4:42 AM
