what are the bars across the engine and can I remove one
97,000 MILES
FRUSTRATED DAVE
this is my daughters car. there is a bar on both the driver and passenger side that goes over the engine. I am draining the coolant in order to replace the hoses, but cannot get to the petcock very easily from either the top or bottom. The air cleaner box is located directly under one of these bars what happens if I move one of these bars to remove the air box? Is there an easier way to get to the petcock. if there is I do not see it. Thank you.
Jan 13, 2017 at 10:12 AM
CARADIODOC
  • 34,414 POSTS
The car will fold up like a road map if you remove those bars!
Well, okay; not really. They are there to stiffen the body and prevent it from flexing on bumpy roads. The engineers expect you to remove them to service the car. It is one of their design characteristics that makes some jobs take longer than on other car brands.
Mechanics avoid the radiator petcocks whenever possible. For about the last twenty years, the valves are made of plastic, and they have rubber o-rings that seal up against plastic. It is real common for those o-rings to be cut or the plastic to crack when they are closed. Also, many of those o-rings are deformed and they do not stretch out when removed. They can be too stiff when they are cold to flex and seal when the valve is closed. It is real common to end up with a leak that drips a drop of coolant about once every five seconds. The fix for that is to replace the radiator. Every shop owner has stories related to their experience with this problem. You are better off just removing the lower radiator hose if you want to drain the coolant.
Jan 13, 2017 at 10:52 AM
FRUSTRATED DAVE
Haha, your joke made my day, lol. I do not know why I did not even think to pull that hose. okay, I feel pretty dumb, lol. That is exactly what I will do in the morning. thank you
Jan 13, 2017 at 10:57 AM
  • 55,694 POSTS
Nice one CARADIODOC lol we would say it would taco! where we are from :)
Thanks for using 2CarPros we are here to help. Tell a friend!
Best, Ken
Jan 17, 2017 at 10:01 PM
