2002 Buick Century re:engine replacement
2002 BUICK CENTURY
130,000 MILES • 6 CYL • 2WD • AUTOMATIC
FEMALEDRIVER
Just received engine and now problems with transmission oil staying in car. I replaced gasket to transmission and now no leak but, where is oil going have to replace every 4 days or so. My coolant resevoir smells like transmission oil and what is suppose to be done along with engine replacement?
confused about where the transmission oil is going.
May 7, 2009 at 1:28 PM
RACEFAN966
  • 5,029 POSTS
Ok if you have trans fluid in the radiator then the trans cooling in the radiator is bad and the only way to fix that is take the radiator to a repair shop and fix the cooler or you cheaper bet may be to just buy a new radiator at your local parts store.
May 8, 2009 at 2:25 AM
