Passenger side electric window not working properly
179,000 MILES • 0.8L • V10 • 2WD
JAMES74501
Window motor on passenger side will go up but not down. I replaced motor and switch.
Aug 8, 2020 at 8:50 PM
Good morning,
I attached a wiring diagram for you to view. Do you have a test light or voltmeter to do some testing?
Aug 8, 2020 at 9:53 PM
JAMES74501
Yes, I have both thanks.
Aug 9, 2020 at 1:22 AM
Does the window work from the drivers side?
Can you check for voltage at the switch with the key on?
Aug 9, 2020 at 1:24 AM
