today saw the thing next to the brake master cylinder.
Images (Click to enlarge)
Oct 2, 2019 at 3:52 AM
✓Experienced Mechanic
Good afternoon,
Is it attached to anything? Looks like it is just laying there.
Oct 2, 2019 at 6:08 AM
ANONYMOUS
MEMBER
0 POST
Check is on.
Oct 2, 2019 at 6:02 PM
Please explain? Do not understand.
Oct 2, 2019 at 7:03 PM
ANONYMOUS
MEMBER
0 POST
The check burns, self-diagnosis does not work. that is, if you close A and B then the check will not burn at all and the cooler will spin and nothing else happens.
Oct 2, 2019 at 7:09 PM
Do you mean the engine will not start?
Do you mean the ECM will not respond to show codes?
Oct 2, 2019 at 7:11 PM
ANONYMOUS
MEMBER
0 POST
Yeah, I mean, the self-diagnosis doesn't work.
Oct 2, 2019 at 8:17 PM
Okay, sorry.
If you jump the 2 pins and it will not flash codes at the check engine light, that indicates a bad ECM. You will need to replace it.
