Wet carpet when A/C or heat is turned on
190,000 MILES • 3.4L • V8 • 4WD • AUTOMATIC
PATTERSON 16
Soggy carpets on driver side only every time I cut heat on or A/C on.
Oct 26, 2020 at 12:25 AM
Good afternoon,
There is a drain hose for the housing that allows water to drain out to the ground. When that clogs up from dirt or debris, it backs up in the car and on to the rug.
I attached a YouTube video for you to view the location and procedure to clean it out.
https://www.youtube.com/watch?v=rRrR6goMNJc
Oct 26, 2020 at 7:10 AM
PATTERSON 16
Thank you!
Oct 27, 2020 at 3:45 AM
