where is the fuel pump relay located
99,000 MILES • 2.0L • 4 CYL • 4WD • MANUAL
ROBERT VEALL
car got wet, but it kept running. It blew the fuse to brake lights. when i replaced the fuse the car cut out and will turn over, but it will not start. I changed the plugs got spark, but will not start.
Oct 19, 2016 at 11:55 PM
HMAC300
  • 48,601 POSTS
this may be a security issue unless you drove car through deep water and it messed up the ECM and other modules. try this link first.
https://www.2carpros.com/articles/how-to-reset-a-security-system
fuel pump relay is in relay box under hood.
Oct 20, 2016 at 2:41 AM
