will not start
170,000 MILES • 3.6L • 6 CYL • 2WD • AUTOMATIC
ECU55
I was driving and it stopped. when I tried to restart the car nothing. It wouldnt turn over. no starter noise. we tried jumping it and still nothing. we checked the fuses. they were all good. when you turn the switch on you can hear the fuel pump and the electric windows and locks work. the dash lights are on and bright. the system is showing 11.5 volts. Also, I do not know if this matters. When I got out to look under the hood I shut the door. When I came back the door was locked. But the driver side rear door was unlocked.
Mar 11, 2017 at 7:02 AM
  • 55,770 POSTS
It sounds like the battery has shorted out and needs replacement, here is a guide to help you get the problem fixed.
https://www.2carpros.com/articles/how-to-replace-a-car-battery
Best, Ken
Mar 14, 2017 at 8:38 AM
