Back shock absorber not working
2004 ROLLS ROYCE PHANTOM
32,234 MILES • 3.3L • 6 CYL • TURBO • 2WD • AUTOMATIC
ONYI
The back shock absorber is not working? I don't know why is not working okay. Thanks and God bless.
Feb 12, 2019 at 6:24 AM
  • 110,241 POSTS
Are you referring to the suspension shocks or a trunk or other strut? When you say it isn't working, can you explain the symptoms?
Thanks,
Feb 12, 2019 at 10:18 AM
ONYI
What I mean is my Air Suspension Compressor pump is not working?. So what should I do? Thanks and God Bless.
Feb 13, 2019 at 9:56 AM
  • 110,241 POSTS
Welcome back:
First, technical information on this vehicle isn't available to me, but I will try my best to help.
The first thing I would suggest checking are fuses. Locate the power distribution box under the hood. Remove the cover. On the underside of the cover should be a legend of what each fuse is for. Locate the one for the air ride suspension and inspect it.
Here are a few links you may find helpful.
Lets start with that. Also, I need to know if the vehicle is sitting low in the rear.
Let me know what you find. Also, if you have the original owner's manual for the vehicle, it should help you locate the fuse box.
Feb 13, 2019 at 11:27 AM
