Clunking sound when braking
88,000 MILES • 3.4L • V6 • 4WD • AUTOMATIC
HWOODS0329
A few days ago I noticed a strange noise start happening when I brake. It is like a clunking sound that slows down with the speed of the car. It only occurs when braking and the intensity of the clunk changes every time. It sounds almost like something builds up tension and then releases with a clunk with every rotation of the tires. Any thoughts?
Again you only hear it when the brakes are applied.
Aug 16, 2021 at 11:59 AM
  • 110,248 POSTS
First, is it loud enough for you to record and upload for me to hear? If it is a clunking, it could be a badly warped rotor, a loose brake caliper, a worn or stuck brake pad, and so on.
When you hear the noise, do you feel anything in the vehicle? For example, does the steering wheel shake or can you feel the noise through the floor? Also, can you tell if it is in the front or rear of the vehicle?
What I suggest is this. We need to check the condition of the brake pads. Since it only happens when the brakes are applied, it is most likely the brakes.
I am going to provide the directions for replacing the front disc brakes and rear drum brakes. These directions are in general, but you can follow them to do the inspection.
https://www.2carpros.com/articles/how-to-replace-rear-brake-shoes-and-drums
https://www.2carpros.com/articles/how-to-replace-front-brake-pads-and-rotors-fwd
Let me know if this helps, what you find, and what I can do to help.
Aug 16, 2021 at 2:37 PM
SQM
  • 6,383 POSTS
Do you feel pulsation on the brake pedal?
What about the steering wheel, does it shake?
Also have you got a chance to do a visual inspection?
Check the brake system like the pads, rotors and the calipers.
You might have something loose or broken. As you slow down the frequency changes with your speed.
https://www.2carpros.com/articles/vehicle-grinding-noise
Let me know what you find and I will be more than happy to assist.
Aug 16, 2021 at 2:39 PM
