when I let off the accelerator there is a whining noise
192,000 MILES • 5.3L • V8 • 2WD
JOHNSON9609
Recently installed a drive shaft. Now reverse is very sluggish and almost act like it doesn’t want to back up. Also, when I’m riding down the road the truck runs great but when I let off the accelerator a whining noise starts and if I push the accelerator down again the noise stops immediately. Any ideas?
Nov 28, 2019 at 10:19 AM
  • 110,248 POSTS
When you replaced the drive shaft, were the universal joints also replaced? Did everything align easily for you?
Nov 28, 2019 at 12:06 PM
JOHNSON9609
The u-joints weren’t replaced and no the alignment wasn’t easy at all.
Nov 28, 2019 at 3:50 PM
  • 110,248 POSTS
Something is either different, went together wrong, or you have bad u-joints. It really shouldn't have been difficult. Are you certain the driveshaft that was used is the same as the original? Also, here is a link that explains how to check u-joints:
https://www.2carpros.com/articles/how-u-joints-work
Removal and replacement directions:
https://www.2carpros.com/articles/how-to-remove-a-drive-shaft
Let me know if anything in the links help.
Nov 29, 2019 at 11:14 AM
