Misfire and intermittent hard start
2004 GMC YUKON
192,000 MILES • 4.8L • V8 • 2WD • AUTOMATIC
LUIS MEDINA2
Hey, so at idle every once in a while the car stutters, RPMs will drop, ABS kick back up to regular idle. Car will shake quite a bit because of the idle drop. Then when I go to drive it if I press the gas a decent amount it’ll begin to feel a hesitation and somewhat of a small couple of backfires or pops. Kind of sounds like it coming from under the cab. There are no exhaust leaks. I used the thermo gun and checked catalytic converters and they’re fine. I checked all exhaust manifold ports and they’re all around 200-230. But I have cylinder 2 at 280-330. so I’m not too sure what that means. And I do have one that drops around 140ish. So maybe that’s why cylinder 2 is hotter because it’s trying to compensate for the other one? I’m not too sure just a thought. Also I have no check engine light on. And I replaced the crank position sensor and cam position sensor and re-learned them both and also nothing has changed. Also sometimes has trouble starting up. Then starts up and buy white cloud of smoke and then just goes away.
Mar 21, 2021 at 4:07 AM
Okay. We need to check two things. First is the fuel pressure when this is happening.
I would suggest taping the gauge to the windshield just so you can see it when it acts up.
Then we need to look into the compression and head gasket. The white smoke and elevated temp points to a misfire and it may be caused by coolant in the cylinder.
Let me know if you have questions and we can go from there. Thanks
Mar 22, 2021 at 12:00 PM
