My car is making a weird noise only after engine has warmed up to normal temperature. The noise is somewhat of a grinding noise but does not sound like actual grinding, more of a fast tapping or rumbling sound. It is hard to describe the noise. Only does the sound when I take off from a red light and only does it for a brief second. I put the car in drive, put one foot on the brake and rev the engine to about 1000 rpm's and it will make the same noise constantly. With only 70,000 miles, I have no clue what it could be other than the starter. Sometimes the starter will whine when a start the car on a cold day. I fear the spring may not be retracting all the way and the flywheel is hitting the teeth on the starter.
Dec 16, 2016 at 11:16 AM
