I'm m trying to replace the rear wheel cylinder brake, for the bleeding valve. I used a 11 mm wrench,but for the the connection between the brake line and the wheel cylinder the wrench 11 mm is too big and the 10 mm is too small. what size wrench did you use? Thank you for your assistance.
Oct 24, 2019 at 10:53 PM
