My cooling fans do not turn at all wear do I find the cooling fen sensor
May 8, 2014 at 5:39 AM
✓Experienced Mechanic
hello. the coolant sensor that controls the cooling fans on and off times is located by the thermostat housing. follow the lower hose from the radiator to the engine and the housing will be there. it will be a 2 wire sensor.
does it work with the ac on???
May 8, 2014 at 7:30 AM
FK2TIRED
MEMBER
no it dose not turn with the AC on but the AC dose not work
May 8, 2014 at 2:13 PM
the sensor that controls the fans is the 2 wire sensor by the thermostat housing. that sends the pcm the info on motor temp, then the pcm grounds the relay that turns on the fans
